cpolizzi
Nov 20, 2024Aspirant
SXR30 and Verizon FIOS
I am trying to replace the CR100B Verizon Router with an SXR30 Router and 1 satellite. I have reset the router to factory settings and it ended with a solid white light. I connected to the router u...
- Nov 25, 2024
I spent 2 hours in a chat with Verizon and they were no help whatsoever. They would not answer a question as basic as, "Do you support 34d party routers in place of your own equipment?"
However, I did finally find the attached document. It appears that the ODN holds onto the IP address lease for their modem blocking attempts to replace their router. By issuing a command to release the IP address on the Verizon router and immediately unplugging it, I could then install the SXR30 with no issues.
Note that the document is from Verizon. All they kept saying was they didn't recommend 3rd party devices as they had a bunch of value added features that they could not elaborate on.
The Verizon solution was to replace the router with an older version (a CR1000A instead of CR1000B) and add 2 network extenders of their own. The newer router my son already had would have to be hardwired to the extenders while the older one could work wirelessly.
Nov 20, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
cpolizzi
I don't think I explained correctly. I am disconnecting the Verizon CR100B and putting the CXR30 in its place. The modem is a Nokia P/N 3FE52343APBB
Thanks.
- FURRYe38Nov 20, 2024Guru - Experienced User
Something to ask the ISP about. Ask them about any special WAN side configurations or if the ISP gateway is required or can be replaced.
