dstrausser83's avatar
Mar 21, 2020
Verizon Fios ONT & AX6000
Ok - I got a weird issue....
I hooked up my Orbi AX6000 directly to the ONT using a Cat7 cable.
Pretty rockin you'd think, right?
Not so much. Speed is actually SLOWER than if I hooked up through their Gateway and sent that to the Orbi.
Thoughts? Should I tweak any settings if it is directly hooked up to the ONT?
BTW - I got TV service, so I connected from an open port in the Orbi to the Internet Ethernet port on the Gateway and I also released the IP addresses and stuff. TV works fine, but I don't know if the gateway perhaps is slowing something down?
EDIT: NAT is OPEN, no double NAT or anything. Also rebooted TV and the TV still works and connects. All services are normal except Internet is slower.
  • FURRYe38's avatar
    v
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too? Built in router here? If so,
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • dstrausser83's avatar
      dstrausser83
      Guide
      No double NAT. I've already verified. All ports are open. All game systems say OPEN. My QNAP NAS is perfectly able to connect, do VPN, etc. No issues what so ever.
      Everything works BETTER but is SLOWER. It was faster, but not as stable using the Gateway. Wondering if something else.
      It's the standard quantum gateway the G1110 or whatever and the standard ONT they use (don't know that model number).
      Double NAT is not the issue, I've verified that. No IP conflicts, nothing of those sorts.
      Thanks though!
        dstrausser83
        Guide
        I have it "set up" correct for the gateway and the orbi. But I'm thinking I may need/want to tweak a setting in the Orbi that is possibly slowing me down.
        I have video working, the Gateway is essentially disabled except for the STBs of the TV service and the Orbi is the main driver.... just working slower. You'd think it'd be faster.
