tlvranas
Dec 18, 2016Follower
R8000 Nighthawk X6 Verizon Frontier FIOS
I am trying to connect my R8000 to my FIOS network and after 6+ hours with this router I still cannot get this working. I am replacing a router that died.
My Set-Up:
Actiontec MI424WR REv. 1 conencted to Frontier via COAX cable.
Router connected to the Actiontec with ethernet cable port 1 to port 1 (not on WAN / INternet port)
Disabled Wireless and DHCP on Actiontec
Enabled DHCP and Wireless on router and everything worked fine for a couple years.
Now I try to do the same thing with the R8000 and it will not work. I have reset everything to factory defaults, connected the R8000 to the Actiontec using the INternet port and it is not able to find / connect to the internet. I followed the rest, power cycle, etc as instructed and nothing.
After some searching, I found some people have them working but ONLY after re-configering the Actiontec to be a bridge, however, this appears to disable TV / VOD.
So my question, how to I connect this 'smart' R8000 to the Actiontec so I can use it for wireless and DHCP without reconfiguring my Actiontec and loosing my TV?
Hi Gstoliby,
You can check with Frontier fios if you can replace the mi242wr with the R8000 and what configuration you need for the router to work.
- storm1985Prodigy
check this KB : http://kb.netgear.com/23734/
- GstolibyAspirantI have frontier fios. We currently rent a mi242wr. I just purchased a nighthawk 48000 because I read online that frontier fios only needs a router. So I have to use the mi242wr still and just use the nighthawk as an access point?
- JamesGLNETGEAR Employee Retired
Hi Gstoliby,
Hi Gstoliby,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
