cpolizzi
Nov 20, 2024Aspirant
SXR30 and Verizon FIOS
I am trying to replace the CR100B Verizon Router with an SXR30 Router and 1 satellite. I have reset the router to factory settings and it ended with a solid white light. I connected to the router u...
- Nov 25, 2024
I spent 2 hours in a chat with Verizon and they were no help whatsoever. They would not answer a question as basic as, "Do you support 34d party routers in place of your own equipment?"
However, I did finally find the attached document. It appears that the ODN holds onto the IP address lease for their modem blocking attempts to replace their router. By issuing a command to release the IP address on the Verizon router and immediately unplugging it, I could then install the SXR30 with no issues.
Note that the document is from Verizon. All they kept saying was they didn't recommend 3rd party devices as they had a bunch of value added features that they could not elaborate on.
The Verizon solution was to replace the router with an older version (a CR1000A instead of CR1000B) and add 2 network extenders of their own. The newer router my son already had would have to be hardwired to the extenders while the older one could work wirelessly.
cpolizzi
Nov 25, 2024Aspirant
- FURRYe38Nov 27, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
