johncasebere
Apr 07, 2021Follower
Orbi Pro - Lack of TX/RX and Association time II
I have an Orbipro network and Lack TX/RX and Association time II data for some components, it does display for others. For example, three of the four satellites show the data and the last one doe...
- Apr 08, 2021
DaneA wrote:A new firmware version was released last March 2021. If ever the current firmware you have is not yet the latest version, I suggest you to update it then check if the same problem will occur.
The latest Orbi Pro WiFi 5 firmware is v2.6.2.200 and you can download it here.
What an advise 8-/ johncasebere please keep in mind to apply a workaround for a known issue -> If your Orbi Pro (SRK60, SXK80) started having frequent client disconnects try this workaround
DaneA
Apr 08, 2021NETGEAR Employee Retired
Welcome to the community! :)
What is the current firmware version of your Orbi Pro WiFi 5 devices? About the old thread you have mentioned, that was almost a year ago. A new firmware version was released last March 2021. If ever the current firmware you have is not yet the latest version, I suggest you to update it then check if the same problem will occur.
DaneA
NETGEAR Community Team
schumaku
Apr 08, 2021Guru - Experienced User
