Frank-NYC
Jan 14, 2021Tutor
Orbi Pro 6 - IOT Client Isolation
Hello, I am looking the Orbi Pro 6 for a home use. It is the front runner for a new mesh network because of the 4 SSIDs (one being IoT). I have been looking at the manuals and I see that there ...
- Jan 21, 2021
Yes, network discovery is verified. I use wireless 3 for my google home devices, set up through the google home app on my smartphone. With network isolation disabled and my iphone connected to wireless 3 I can see all the devices and set them up, and all the google home devices are found by and are controllable by the google home mini.
YMMV but with the google home devices on wireless 3 with client isolation disabled, you have network discovery.
Steve
schumaku
Jan 15, 2021Guru - Experienced User
Frank,
Frank-NYC wrote:But I have not been able to find out if this can this be disabled the isolation to allow IoT devices (like Sonos, TVs, Streaming devices, Video server, etc) to interact with each other within the Wireless 3 network.
What sounds interesting and is often propagated will often not work without loosing many features. Assuming it would be a plain IPv4 router, you can't use any Multicast based discovery (like Bonjour or UPnP SSDP) beyond of each network. Do you intend to change the wireless network if you intend to play music or a movie to a media player?
This wonderful security theory is workable only for IoT requiring no control from e.g. a mobile App on the same network, or where everything is handled and controlled over the Cloud.
I admit, I'm not up to speed on the current Orbi Pro firmware implementation. While there might be a control to enable/disable wireless isolation (over the complete SSID) for this network, there is certainly no simple firewall user firewall matrix config with three source and three destination networks where a user could allow or deny.
As well, I doubt there is any multicast routing between the three IP subnetworks, too.
I don't understand why the very basic controls and mandatory features are not available on these and many similar routers and mesh systems in this market segment.
-Kurt
Frank-NYC
Jan 15, 2021Tutor
Thanks for the reply Kurt, but maybe I should clairify my question and limit it to one point.
All of the following is related to Orbi Pro 6 Wireless 3/IoT SSID/Network. (or has one figured out a way to get an IoT friendly segment on another mesh network product?)
I am looking to add many types of IoT, media, automation, video on this SSID/Network and I am looking if it can be that those devices can talk to each other on that network.
For example:
-Cameras with NVR (camera send data over the internal network to the NVR/DVR)
-Sonos (unit with the HDMI input from the tv send data to other speakers for subwoofer/surround sound)
-IP remote or app control (control of the devices over the network, with all devices, even the mobile device with app on the Wireless 3/IoT SSID)
Can client isolation on Wireless 3/IoT SSID be disabled or is there a function "allow clients to talk to each other" on Wirelss 3/IoT?
Thanks again,
Frank
