rtist2g's avatar
rtist2g
Disable AP isolation
Hello, I'm interested in your Orbi Pro 2 unit kit for a photo studio. I'd need the Pro version vs the home version because I need to create a few different SSIDs for the seperate business units that are in the studio, however I do not want to isolate the networks for the simplicity of playing music to sonos speakers, or airplay to Apple TV's etc. I see that AP isolation is a *feature* but i don't see if there is an option to turn it off. Can you please clarify that I can turn AP isolation OFF?
  • rtist2g,
    It seems that what you are referring to is a different term, its not "AP isolation" because there are no access points involved.
    With the latest firmware version of the Orbi Pro which is v2.2.1.210, there is now an option in the  Wireless 2 SSID wherein you can allow employees to see each other as well as give access to the local network.  With this feature, you can allow your employees to access the Sonos speakers located in the local network.
    Kindly refer to the screenshot below:
    Let us know if have further inquiries.  Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi rtist2g,
    Welcome to the community! :)
    There is no option to create a different SSID other than the 3 default SSIDs, namely: Admin WiFi network, Employee WiFi network and Guest network.
    I'm afraid to inform you that there is no option to turn off AP isolation.
    DaneA
    • rtist2g's avatar
      rtist2g
      Hi DaneA, thanks for the reply.
      In looking at the most recent firmware release notes, it states:
      Added the “Allow employees to see each other and access my local network” feature on Wireless 2 network
      Doesn’t this allow the employee network access items like sonos speakers etc?
    • DaneA's avatar
      DaneA
      rtist2g,
      DaneA
      • rtist2g's avatar
        rtist2g
        Thanks DaneA, that's exactly what i was looking for. Sorry for the incorrect terms, I guess thinking about it further, i should have said SSID isolation? Either way, this will work for my needs. That firmware update was just in time.
ProSupport for Business
