rtist2g's avatar
rtist2g
Disable AP isolation
Hello, I'm interested in your Orbi Pro 2 unit kit for a photo studio. I'd need the Pro version vs the home version because I need to create a few different SSIDs for the seperate business units that ...
  • DaneA's avatar
    DaneA
    Nov 25, 2018
    rtist2g,
    It seems that what you are referring to is a different term, its not "AP isolation" because there are no access points involved.
    With the latest firmware version of the Orbi Pro which is v2.2.1.210, there is now an option in the  Wireless 2 SSID wherein you can allow employees to see each other as well as give access to the local network.  With this feature, you can allow your employees to access the Sonos speakers located in the local network.
    Kindly refer to the screenshot below:
    Let us know if have further inquiries.  Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    DaneA
    NETGEAR Community Team
ProSupport for Business
