Before You Buy
14 TopicsSXR80 under warranty, but end of life
Hello, We have an SXR80 router and 2 SXS80 satellites. All are under warranty, but Netgear has EOL'd these devices. That means that there are no more firmware updates, etc. What are our options for replacing these? I mean, they weren't cheap and now they're not even supported by the manufacturer. Warranty doesn't mean much in this instance, does it?1.2KViews0likes8CommentsWPA2-Enterprise Support on Orbi Pro
I purchased an Orbi Pro system for my law office and was surprised to discover that this $500 business-class device does not support WPA2-Enterprise, which has been supported by default on each of the many ~$100 consumer-grade wifi routers I have owned in the past ten years. I would request that Netgear consider implementation of this standard as an urgent priority for the next firmware update.SolvedDon’t buy Orbi Pro…Buy something else. Anything else…
Don’t buy Orbi Pro…Buy something else. Anything else… I own Orbi Pro with two Pro Satellites. I also own the Orbi Outdoor RBS5OY. Here are my problems and reasons to avoid anything product Netgear manufactures. If your intension is for business. I updated to the recent GA firmware 2.2.2.210. It did not cause any obvious problems on day-1, beyond the normal Orbi known issues (drops, reboots, etc). However, I did notice my ability to transfer large files across my WIFI dropped speed considerably. I have no illusion that WIFI speeds don’t range and fluctuate randomly. I also know interference and other variables can cause problems. But I have historically been able to get 300-500 Mbps tested and validated using INTERNAL LAN TEST NETWORK PERFORMANCE TOOLS, not internet speed checks which are less reliable... I am a 20 year tech worker with extensive knowledge and experience with enterprise network devices, including WIFI and RF products. I know how to tweak and tune my Orbi to insure the most optimal performance. So, why did my speeds drop to 100-200 after applying the recent firmware. I did role back to 2.2.1.210. Factory resets, reboots, full re-configure. Hours wasted… Same result. Slow speeds. I considered rolling back to previous firmware, but you must be using at least 2.2.1.210 to avoid Netgear Orbi automatic updates. And typical Netgear. Silent! Repetitive! Script Kiddy responses. You may think you are interacting with a BOT with template answers. You are ON YOUR OWN! After they get your money. Netgear opened a thread MONTHS ago. Asking Orbi Pro users what features they would like to see. Most Orbi Pro users quickly understood that “PRO” was nothing more than a spin-off of Orbi Consumer version with nearly 90 percent parity. But, we can forgive Netgear. After-all, they are interacting and working with the end-user (that’s you) to build Orbi Pro into something truly business-like, custom built with the user’s input as the driving force. Current Day…Months later….NOTHING WE SUGGESTED has been implemented. They “tried” to use clever tricks such as “VLAN SUPPORT” has been added. But we all quickly learned. It was for ISP and router mode only. As of today, there is little, nearly ZERO difference between Orbi Consumer and Pro versions. Yet, Pro users paid far more to have the “PRO” logo on their product. Netgear advertised another VERY COOL product called Orbi Outdoor RBS5OY. I do have a very large outdoor space. And often I like to stream music and control my smart devices via my smartphone, and maybe do some work outside. So Orbi Outdoor was a GIFT from Netgear, as now my entire outdoor space is covered with great WIFI!!! Thanks Netgear! A true gift! Or…is it a gift with a nasty secret that Netgear has yet to respond. The RBS5OY is based on the Orbi consumer version. Not Pro. Yet, Netgear very openly and loudly claims this RBS5OY is compatible and fully works with Orbi Pro. But is that TRUE???? I have asked Orbi why the firmware for RBS5OY is not aligned with Orbi Pro. The obvious answer is the RBS5OY firmware code is based on Orbi consumer firmware. So, as Orbi Pro receives new updates, promised features, BUG FIXES….as Netgear has released 2 new updates for Orbi Pro….Does anyone notice Orbi Outdoor is not getting those same updates? How does Netgear intend to unify the new features and BUG FIXES and stability and other advertised “Pro” stuff…when you have this third-wheel product they charged you $500 for….that is not running the same firmware? Imagine your car manufacture selling you a performance part for your car. Only they updated your car with fixes and other changes, only to learn your performance part was not updated to work those changes. Does this mean the manufacture is going to fully refund you for an add-on that will not work properly with your updated vehicle? Still, no reply from Netgear about this? But they got your money. Orbi support is widely known to be a joke. You are better and more wise to use Reddit or other methods to solve your problems. Any idea of a business using Orbi Pro and expecting business style support. GOOD LUCK! Considered yourself warned. I am not saying Netgear is the horrible company. I believe Netgear does many great things. Perhaps Orbi Pro was and is more than Netgear can handle. This is not Netgear’s first attempt to get inside the business tech market. But common sense people. How many Netgear products do you see within ANY tech company? For the many users that often complain to this forum. I say this with respect and understanding. STOP!!!!!!! Netgear has already given us the answer. They don’t care! They are not going to follow through with promises. They are not going to improve support! Orbi Pro is NEVER going to be what you want it to be. Go buy something else. Netgear has been responding to all of us since the day Orbi was released. What has changed? They fix one thing…They break another….They promise 5 features….You are lucky if you get one of those features usually a year or longer later…Netgear has a scripted and default response to any problem you have. It “may” be possible they only have 3-4 support people working for them and they heavily rely on a copy/paste response to all questions and problems. I own Orbi Pro. I drank the kooliade. But I also protected myself via a third-party warranty that will allow Orbi to be replaced. I thought I would wait until early 2019 and see what Netgear does. Give them a chance! Be patent, as my parents taught me. But they also taught me to NOT BE A FOOL…. So…Don’t buy Orbi Pro…Buy something else. Anything else… I will live with Orbi for a few more weeks. But I am positive I will need to use that warranty and have Orbi replaced. Perhaps dig a little deeper in my pocket for something TRULLY made for business. Of course, I am open to any response from Netgear. I am a civilize and open-minded person. I believe in fairness and respect and honesty. I am willing to work with Netgear concerning Beta firmware that specifically addresses promised business PRO features. But not allowing myself to be your lab rat….while you continue your course of using consumers as your testing ground for baseline support and stability that SHOULD have already need delivered. As of now…I have a 2-3 year old Gen-1 802.11AC ASUS RT3000 that is faster than this $2000 Orbi Pro…Solved18KViews6likes11CommentsOrbi Pro Ceiling Satelite - Innovation Award Honoree #NetgearCES2019 Day 2
Our #NetgearCES2019 Coverage continues now featuring Orbi Pro Ceiling Satellite. Perfect for those tricky deployments where only PoE+ or an AC power outlet is available. Orbi Pro is particularly useful for large open areas with medium and low density of devices such as warehouses. Learn more about it below. Stay tuned to the NETGEAR Business Community for additional coverage from CES 2019. Let us know what you think of the Orbi Pro Ceiling Satellite. Product Name: Add-on Orbi Pro Ceiling Satellite (SRC60) Model Number: SRC60 Availability: Coming Soon Description: As an honoree for the 2019 CES Innovation Awards in the Smart Home product category, NETGEAR Business’s Orbi Pro Mesh Wi-Fi Ceiling Satellite connects with the Orbi Pro Router or any other Orbi Pro satellite via the patented FastLane3 technology with a dedicated wireless backhaul for environments where wiring is challenging or impossible. Alternatively, in new builds or office expansions where power outlets are unavailable or new AC wiring is cost prohibitive, the Orbi Pro Ceiling can be powered by using ethernet cables with (PoE) utilizing 4x4 MU-MIMO Wi-Fi to cover denser environments. Automatic power and channel management between satellites enable superior roaming, coverage and performance making Orbi Pro the ideal solution for large areas. Performance: Tri-band AC3000 Mesh WiFi Satellite - 2,500 sqft. 1.7gbps wireless backhaul Product Page: Orbi Pro Ceiling Satellite SRC60 Press Release: Orbi Pro Ceiling Satellite Press Release Stay tuned for additional CES 2019 Coverage for Day 1 on this page, and all of our #NetgearCES2019 Coverage https://twitter.com/NETGEAR/status/1083482206998212608
Solved9.6KViews2likes5CommentsDisable AP isolation
Hello, I'm interested in your Orbi Pro 2 unit kit for a photo studio. I'd need the Pro version vs the home version because I need to create a few different SSIDs for the seperate business units that are in the studio, however I do not want to isolate the networks for the simplicity of playing music to sonos speakers, or airplay to Apple TV's etc. I see that AP isolation is a *feature* but i don't see if there is an option to turn it off. Can you please clarify that I can turn AP isolation OFF?SolvedPre Purchase Questions
Hi Folks, I new to the forum so treat me gently! I've been running a 6 disc BT Whole Home successfully for about a year. The latest firmware update has broken the system beyond repair for now. I'm looking for a replacement and although the Pro is for small business I think it might be a solution for my needs but I wanted to check some items I'm looking for are there when in AP mode - through the Orbi UI you can see the list of clients connected to the Orbi - clients connected to the upstream modem/router e.g. nas drive can be seen by devices connected via the orbi?Solved2.7KViews0likes2CommentsOrbi Pro Ethernet Backhaul
Hi, Does Orbi Pro now support ethernet backhaul between router and satellite (like Orbi for Home RBK50)? My router and satellite will be located in separate buildings with some distance and thick walls, i.e. they need to be wired together. Best regards, StefanSolved9.4KViews0likes4CommentsUsecase for Orbi Pro vs Wac510
I have a small business and own a couple of insight managed switches and are looking into extending the solution with option for wireless access for the employies. But with the annoncement that Orbi Pro will be supported in Insight Management I have a hard time finding what solution is right for me. What are the main differences between Wac510 and Orbi Pro? What is only possible with Wac510? What is only possible with Orbi Pro? Orbi-Pro-WiFi-System-to-Receive-Insight-Management-App-SupportSolvedOrbi Pro SRK60 Questions (before purchase)
I'm looking to use the Orbi Pro in a client's building that is dual-level. Probably 6000-7000 sq feet total. Can the Orbi be used as access points only? I don't want to replace my business-class router. I'd like to use the Orbi for their excellent mesh coverage, but only as access points. Can this be achieved? One Orbi plugged into my existing router, then blast out the signal and 2-3 more Orbi's around the building to create that mesh network? Do you also think 3 Orbi Pros will be enough bandwidth to handle at least 15 people having their cell phone connected and 3-4 laptop workers who roam around the office? Any thoughts about all this? Thank you.Solved7.3KViews0likes3Comments
