dmoby
Jan 21, 2018Follower
RBS50Y compatible orbi Pro ?
Hello,
Is the outdoor unit RBS50Y also compatible with the pro version of orbi ?
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi dmoby,
Welcome to the community! :)
Yes, it is compatible. As per the RBS50Y data sheet here, it is required to have either the Orbi Home router (RBR50 or RBR40) or Orbi Pro router (SRR60) to sync the RBS50Y Orbi Add-on Outdoor Satellite.
For more details, kindly access the link below:
Add-on Orbi Outdoor Satellite (RBS50Y)
DaneA
Cheers,DaneA
