dmoby
Jan 21, 2018Follower
RBS50Y compatible orbi Pro ?
Hello, Is the outdoor unit RBS50Y also compatible with the pro version of orbi ?
- Jan 24, 2018
I just want to follow-up on this. Let us know if you have further inquiries.
Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
