rtist2g
Nov 22, 2018Aspirant
Disable AP isolation
Hello, I'm interested in your Orbi Pro 2 unit kit for a photo studio. I'd need the Pro version vs the home version because I need to create a few different SSIDs for the seperate business units that ...
- Nov 25, 2018
It seems that what you are referring to is a different term, its not "AP isolation" because there are no access points involved.
With the latest firmware version of the Orbi Pro which is v2.2.1.210, there is now an option in the Wireless 2 SSID wherein you can allow employees to see each other as well as give access to the local network. With this feature, you can allow your employees to access the Sonos speakers located in the local network.
Kindly refer to the screenshot below:
Let us know if have further inquiries. Otherwise, if ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Nov 25, 2018NETGEAR Employee Retired
Hi rtist2g,
Welcome to the community! :)
I'd need the Pro version vs the home version because I need to create a few different SSIDs for the seperate business units that are in the studio, however I do not want to isolate the networks for the simplicity of playing music to sonos speakers, or airplay to Apple TV's etc.
There is no option to create a different SSID other than the 3 default SSIDs, namely: Admin WiFi network, Employee WiFi network and Guest network.
I see that AP isolation is a *feature* but i don't see if there is an option to turn it off. Can you please clarify that I can turn AP isolation OFF?
I'm afraid to inform you that there is no option to turn off AP isolation.
DaneA
- rtist2gNov 25, 2018AspirantHi DaneA, thanks for the reply.
In looking at the most recent firmware release notes, it states:
Added the “Allow employees to see each other and access my local network” feature on Wireless 2 network
Doesn’t this allow the employee network access items like sonos speakers etc? - DaneANov 25, 2018NETGEAR Employee Retired
Regards,DaneA
