hocuslocus
Nov 18, 2020Aspirant
ORBI pro AC3000 issues with wifi not issuing new IP addresses. (SR660)
I've tried calling tech support 3 times. they keep asking for the same info. and then telling me they need to transfer me to "that department" they sent me back to regular tech support the first ti...
hocuslocus
to be more specific I have a dedicated set of addresses for the wired/wireless static devices via the settings only uses maybe 50-60 addresses. Even addresses that were issued prior to the power loss can be reissued via DHCP, but no new devices.
I have a guest network setup for customers, that can use the remainder. Usually it's only like 4 or 5 people using it at a time though, so no where near the limit.
Everything always works fine until the unit turns off/on. then it takes a day or two before it starts acting normally again.
The only reason its off at all is due to power loss at the specific location.
JohnC_V
Nov 20, 2020NETGEAR Employee Retired
Welcome to our community! :)
It seems that you are having issues with your Orbi Pro. May I know if your Orbi Pro and satellites are up to date? If not, please try to upgrade the firmware to its latest version. You may download the latest firmware here.
John
NETGEAR Community Team
