davidcheok
Sep 18, 2019Apprentice
Orbi Pro Firmware update - V2.4.0.114
Just updated the firmware to the latest today. Nothing seems to have changed. 1) 2nd Wifi still gives a third open SSID (initially seems to work but 3rd open ssid appeared again after some time) 2...
- Sep 18, 2019
Did you see the issue on 2.3.5.108? then update FW to 2.4.0.114, still see the issue,
if you see the issue on 2.3.5.108, then update to 2.4.0.114, but config don't change after update, so the issue still happen on 2.4.0.114,
Please disable WiFi 2 and Enagle again on 2.4.0.114, it won't see the issue again,
We will fix it in next maintance release.
davidcheok
Its not a prudent policy to put unknown clients on your company network. Doing so simply invites potential hacks and with the large variation of malware out there infesting various o/ses, it would be a matter of time one propagates into an internal client. I would think it would be a simple job to create say separate private network to host these 'guests' especially since your guest ssid is unsecured. Dont know but thats just my logic.
evan2
Sep 18, 2019NETGEAR Expert
