Retired_Member
Jun 05, 2021Orbi Pro Firmware
Hello Community... Curious......what Firmware version are you using? That has been Stable? This is for Orbi Pro AC3000 Wifi 5 Tri-band SRK60 (plus SRS60). The 2.6.2.xxxx versions have been qui...
stofferr
Jun 09, 2021Tutor
1 SRR60 and 2x SRS60 -> fw 2.6.2.200 and since then instable (frequent client disconnects) -> this is so much a problem that I have shut them down and replaced with another brand device (still have my previous device).
Coverage and speed of my replacement device are less but at least they are stable.
Netgeat PLEASE fix the 2.6.2.200 ASAP!
RaghuHR
Jun 21, 2021NETGEAR Expert
Hi stofferr
Could you please send us the debug log at time of the issue? We will investigate and provide our analysis.
Edit: Received your logs. We will investigate and provide an update.
Thanks,
Raghu
- Retired_MemberJun 21, 2021No you won't.....wow....cant believe it....another ask for logs files
besides, I am not haveing any problems. 2.5.5.100 is running perfectly......
