LarsA
Dec 16, 2019Aspirant
Orbi pro set up for google home
How to set up Orbi pro so it's working with google home, with the regular Orbi it's not any problem, but with the Orbi pro google home lose the wifi signal frequently.
- Jan 02, 2020
Hi, as I was informed by the Swedish netgear suport team that I can`t use google home with Orbi pro, did I return my home assistant to the store again, so I can`t produce any report to you. I will close the thread for now. I will try a new google home assistant later on.
JohnC_V
Dec 17, 2019NETGEAR Employee Retired
Hi LarsA,
Welcome to our community! :)
NETGEAR doesn't recommend to have a 3rd party to be connected on the Orbi/Orbi Pro.
John
NETGEAR Community Team
- schumakuDec 21, 2019Guru - Experienced User
Hm JohnC_V I think you mix up something: Google Home is a smart speaker, not a mesh or the like network.
- JohnC_VDec 25, 2019NETGEAR Employee Retired
My apologies. I overlooked that one and I was referring to Google Mesh.
John
- schumakuDec 26, 2019Guru - Experienced User
Hey JohnC_V - please don't worry, we all hit similar traps every now and then in attempt of assisting Netgear customers here. Very often it's difficult to decode and understand the issues posted. Thank you for all your efforts over the years. Happy Holidays!
PS. I'm considering to massively reduce my time and efforts with this community - because of Negear (not you personally!) is unable to say "Thank you!".
