LarsA
Dec 16, 2019Aspirant
Orbi pro set up for google home
How to set up Orbi pro so it's working with google home, with the regular Orbi it's not any problem, but with the Orbi pro google home lose the wifi signal frequently.
- Jan 02, 2020
Hi, as I was informed by the Swedish netgear suport team that I can`t use google home with Orbi pro, did I return my home assistant to the store again, so I can`t produce any report to you. I will close the thread for now. I will try a new google home assistant later on.
RaghuHR
Dec 29, 2019NETGEAR Expert
Hi LarsA
We need debug logs to understand why your google nest is having connection issues with Orbi Pro. Please help us to provide the debug log mentioned below:
Go to the http://<ip address of orbi pro>/debug.htm.
Then click on start capture. Wait for the issues to happen and save the debug logs.
Please wait at least 5 mins before saving the logs to record everything in the logs.
You can upload debug into google drive and send me link via PM.
Hope you can provide the debug logs soon.
Have a nice day!
Raghu
nmhTester
Dec 30, 2019NETGEAR Employee Retired
I did not see any issues with SRR60 running latest V2.5.0.108
Setup :
Internet===SRR60(Router mode)~~~wireless backhaul~~SRS60
I have three wireless clients for this test.
Android phone running Google Home app.
Google Speaker
Macbook Pro.
all joined to SRR60 (due to the proxmity)
What SSID are you using ?
I am using SSID1 and I am able to do the following :
1) Discover and Add factory reset Google Home speaker from Android home and Google Home App.
2) cast music from Chrome browser of Macbook Pro on the Google Home speaker (same SSID).
3) use Google Home app on android phone and cast music from Google play Music to the speaker. With bluetooth or via Wifi Audio casting.
In my case all the three devices on SRR60 as these were in same room. I did not try getting speaker connected across to a SRS60 in the other room as I have disconnected it for now.
I have music (audio cast) going for 30 mins now and there has been no disconnects or drop off.
So it is safe to say there is no system wide inter-op issues with OrbiPro and Google/Nest speakers.
however, please work with RaghuHR to share your detailed setup and debug capture.
- RaghuHRJan 01, 2020NETGEAR ExpertHi Lars-Åke Jävert , Do you have any further update and debug logs for your Google home connectivity issue with Orbi Pro? Please update otherwise please mark this thread close. Thank you, Raghu
- LarsAJan 02, 2020Aspirant
- nmhTesterJan 03, 2020NETGEAR Employee Retired
Just to conclude,
OrbiPro will support all the standard 802.11 (Wi-Fi) clients.
apologies for any confusion created.
Thank you everyone for bringing this to a closure.
