serbes
Oct 25, 2020Tutor
orbi pro srk 60
Hello,
I have a wifi installation in a school (orbi pro srk 60 with 9 SRS60)
New users regularly do not know how to connect due to lack of ip address
This problem happens around 60 users are...
- Oct 25, 2020
Out of the box, the SRR60 does max out the possible IP subnet address range with 192.168.1.2 to 192.168.1.254, see ADVANCED > Setup > LAN Setup.
One thing that hits my eye is the set-up with router plus nine satellites - AFAIK the max number of satellites supported is six. Are your satellites on a wired backhaul or is this a completely wireless set-up?
schumaku
Oct 25, 2020Guru - Experienced User
serbes
Oct 26, 2020Tutor
Thank for your quickly answer,
Thank you for your prompt response
Indeed the range of addresses varies from 192.168.1.2 to 192.168.1.254 by default
Can we increase beyond that?
Or get the addresses of users leaving the network quickly?
Thank you in advance for more
Serbes Ali
