Marco-F's avatar
Marco-F
Orbi Pro SRK60 - Ethernet backhaul vs WiFi backhaul for mesh WiFi in large multi-story house.
I have read in some blogs that for the Orbi Pro SRK60 system it is better to establish a WiFi backhaul using the dedicated radio signal between units, rather than the Ethernet backhaul.
As I'm designing the system for a large house and 5 satellites, I have the opportunity to have wired connections in a daisy-chain design.
I was assuming the Ethernet backhaul is far more reliable and stable than the WiFi one.
If so, why someone would suggest to rely on the WiFi backhaul instead?
Thanks.
  • Marco-F
    Yes, Ehternet backhaul is more reliable and stable than the WiFi backhaul,
    If you have the opportunity to have wired connections in daisy-chan, you had better use Wired connections.
  • evan2's avatar
    evan2
    NETGEAR Expert
    Marco-F
    • Marco-F's avatar
      Marco-F
      evan2 wrote:
      Marco-F
      Great! Thanks for confirming!
ProSupport for Business
