HRZNHyde's avatar
HRZNHyde
Orbi PRO SRK60 satelitte different wifi details than router
Hi   I recently purchased the Orbi PRO SRK60 with one satelitte. I am currently using a technicolor dga2231 modem/router and POE switch provided by my ISP. I've tried setting up the Orbi Pro using ...
  • JohnC_V's avatar
    JohnC_V
    May 07, 2021
    HRZNHyde,
    Thank you for that information. They will appear as a different WiFi connection because it is set on AP mode. This will provide its own SSID and will still have the seamless connection working. May I know if the router and satellites are running on the same firmware version? If not, please update the firmware to its latest version.
    John
    NETGEAR Community Team
ProSupport for Business
