tonator
Jan 06, 2021Aspirant
Orbi Pro (SRK60) Wifi problems with online gaming
Hi, I have a fiber-optic internet connection at home (modem is CTS FWR5-3105). Netgear Orbi Pro (SRK60) router is connected to bridge mode port of fiber-optic modem. If I try to play online ga...
DaneA
Jan 11, 2021NETGEAR Employee Retired
Welcome to the community! :)
The only problem is Orbi wifi with fiber-optic connection. And the problem is with games, not with Internet browsers or video streams (Youtube, Twitch etc).
There might be ports that needs to be opened for the games you play.
Are you playing games using a PC?
What are the wireless settings configured on the SRR60?
DaneA
NETGEAR Community Team
tonator
Jan 11, 2021Aspirant
I tried this solution a couple of months (1 year?) ago, but I think it was not possible to open many enough for Counter Strike for example. And why everytning was fine with the Same SRK60 and 4G connection? Ports for CS:GO are
- TCP: 27015-27030,27036-27037
- UDP: 4380,27000-27031,27036
Yes. Windows 10.
What do you mean especially?
- 2,4 Ghz channel automatic (Auto ( 5(P) + 9(S) )), 5 Ghz 36 (tested also other choices) (36(P)+40+44+48)
- WPA2-PSK [AES]
Router information
- DHCP enabled
- Router-mode
Advancedd settings attached (I didn't manage to add photo in the text)
Does this help?
