tonator
Jan 06, 2021Aspirant
Orbi Pro (SRK60) Wifi problems with online gaming
Hi, I have a fiber-optic internet connection at home (modem is CTS FWR5-3105). Netgear Orbi Pro (SRK60) router is connected to bridge mode port of fiber-optic modem. If I try to play online ga...
schumaku
Jan 11, 2021Guru - Experienced User
tonator wrote:I didn't have these problems when I had same computer and Orbi system with 4G-connection (router was Huawei B593). Everything works great when using Wifi from fiber-optic modem, too. There is neither problems when connecting my computer to Orbi router with cable. The only problem is Orbi wifi with fiber-optic connection.
When I get you right, two alternate Internet connections work or worked fine on the vey same Orbi Pro GbE WAN port - and the issue is "just" with this bridged Internet port on the CTS FWR5-3105? hmm...
tonator
Jan 12, 2021Aspirant
Correctly. I also have turned off CTS 5 GHz wifi.
- RaghuHRJan 19, 2021NETGEAR Expert
Hi tonator
Are you using EU SKU?
Could you please share the debug logs? Go to https://<ip address of Orbi Pro>/debug.htm
Click on start capture.
Recreate the issue.
Save the debug logs.
Upload debug into google drive or similar and send me link via PM
- tonatorJan 19, 2021Aspirant
RaghuHR wrote:Hi tonator
Recreate the issue.
Hi RaghuHR
Yes, I'm using EU SKU.
I sent a private message that includes link to debug log.
