zerus
Aug 17, 2022Follower
Orbi Pro SRR60 as satellite
Hi, I want to use a second SRR60 as satellite (similar to this https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Can-I-use-the-Orbi-Pro-SRR60-Router-as-a-satellite/m-p/2096358#M3445...
Aug 17, 2022Guru - Experienced User
No. Its not.
The SRR is a router only device. It can be used in access point mode with another SRR but it won't integrate with the mesh system.
And the flashing question? You'd be better off to try on a site that allows that with the consumer RBR and not on the official forums.
