yerge02
Mar 16, 2021Tutor
Orbi Pro SRR60 keeps disconnecting
Currently running the SRK60 Orbi Pro. My SRR60 router is running firmware version v2.6.2.200. Recently, my router has been losing its internet connection. This happens several times in a day. Eac...
JessicaMulein
Mar 18, 2021Star
Same modes SRK60 with 2 satellites. I actually upgraded to an SXR80 and HAVE THE SAME PROBLEM!
After seeing your post I've reverted one firmware version back on the SXR80. Trying that out. The WAN just keeps going unavailable. Standard Xfinity DCHP. No brainer. Maddening for days. Started after FW update this weekend.
- JohnD333Mar 18, 2021ApprenticeJessica,
What version firmware for SXR80 did you revert back to? I am at 3.2.1.102 on my SXR80 and 2 satellites. An update is available but I am reluctant to do so. I had rock solid internet connections and reserved IP addresses were saved on reboot with the previous version but not 3.2.1.102. Srx80 drops internet like clockwork every 2-3 days for 2-4 minutes. It is not the service provider. Everything is on battery backup so it is not the power supply either.
PS, while there seems to be a common firmware issue, this string is really about the SRK60 series not the 80 series, so we should get over to the SRX80 postings.
Thanks- JessicaMuleinMar 18, 2021Star
Am currently on 102. Haven't been on long enough to decide if it's fixed.
I did have an SRK60, but took it offline. I'm not likely to return to it as my peak bandwidth was 250mbps. Now I'm seeing 950 to 1.2gbps... but the same WAN/dhcp drop. *sigh*
- odbammbMar 18, 2021Star
I did find something strange (2.6.0.108). When I looked at the DHCP lease time expire it had only 30 minutes left on it. And I hard powered down the router a few hours before. I went back in a few minutes later and it was just under 8 hours now... DHCP lease obtained is only 8 hours, but DHCP lease time parameter is set to 24 hours and can not be increased. So that parameter does not match what the router is actually running. Any thoughts???
I will keep an eye on this. Also might try checking and release/renew the lease when I first log in.
- JessicaMuleinMar 23, 2021StarModes - > model....
