yerge02
Mar 16, 2021Tutor
Orbi Pro SRR60 keeps disconnecting
Currently running the SRK60 Orbi Pro. My SRR60 router is running firmware version v2.6.2.200. Recently, my router has been losing its internet connection. This happens several times in a day. Eac...
JohnD333
Mar 18, 2021Apprentice
Jessica,
What version firmware for SXR80 did you revert back to? I am at 3.2.1.102 on my SXR80 and 2 satellites. An update is available but I am reluctant to do so. I had rock solid internet connections and reserved IP addresses were saved on reboot with the previous version but not 3.2.1.102. Srx80 drops internet like clockwork every 2-3 days for 2-4 minutes. It is not the service provider. Everything is on battery backup so it is not the power supply either.
PS, while there seems to be a common firmware issue, this string is really about the SRK60 series not the 80 series, so we should get over to the SRX80 postings.
Thanks
Thanks
JessicaMulein
Mar 18, 2021Star
Am currently on 102. Haven't been on long enough to decide if it's fixed.
