yerge02
Mar 17, 2021Tutor
Orbi Pro SRR60 keeps disconnecting
Currently running the SRK60 Orbi Pro. My SRR60 router is running firmware version v2.6.2.200. Recently, my router has been losing its internet connection. This happens several times in a day. Eac...
odbammb
Mar 18, 2021Star
I did find something strange (2.6.0.108). When I looked at the DHCP lease time expire it had only 30 minutes left on it. And I hard powered down the router a few hours before. I went back in a few minutes later and it was just under 8 hours now... DHCP lease obtained is only 8 hours, but DHCP lease time parameter is set to 24 hours and can not be increased. So that parameter does not match what the router is actually running. Any thoughts???
I will keep an eye on this. Also might try checking and release/renew the lease when I first log in.
odbammb
Mar 18, 2021Star
More weirdness. The purple light on the router goes on and I can not connect to the internet. BASIC Home pages shows no intenet connection. When I select that it brings up another screen and searches for the internet and finds it after a minute or so and we are good again. The outages are happening more and more frequently. Now less than an hour between.
