yerge02
Mar 16, 2021Tutor
Orbi Pro SRR60 keeps disconnecting
Currently running the SRK60 Orbi Pro. My SRR60 router is running firmware version v2.6.2.200. Recently, my router has been losing its internet connection. This happens several times in a day. Eac...
Anonymous
Mar 18, 2021Another botched firmware release.....That is now TWO bothched releases......
What a waste......
My ISP is still funtioning just fime......despite I get an error when looking at the router IP GUI....
Hey Netgear - Good like getting any addisional revenue from Insights when you release bugging firmware.....
I would suggest downgradeing until the so-called "Engineers" come up with a fix.......
Two bad bitched up releases......Netgear is causing our business to lose money and time......
What a waste........
Cheezdoodlez
Mar 18, 2021Star
Same thing happened to me. the v2.6.x.x firmware is breaking everying. I was able to get back to a useable state by rolling back to V2.5.5.100.
Its sad that this is necessary. 2.6.x.x is breaking both DNS and causing packet loss as well. Please try to old firmware and le me know if this works for you as well.
- yerge02Mar 18, 2021Tutor
Out of desperation I picked up a wired router and just demoted my Orbi Pro to AP mode. Between work and my kid's remote schooling, I could not afford the downtime. Not an ideal solution but I am back up and running now.
- BruceGuoMar 19, 2021NETGEAR Expert
The problematic AP is standalone mode or managed by Insight?
- odbammbMar 19, 2021Star
Let me recap my problem. It is specifically that the router keeps disconnecting from the internet. There is not a problem with connected devices dropping. The cable modem has been checked both when the router is working and drops the internet. The cable modem, lines and service are all good.
I have been wrestling with this for 5 days now since the latest firmware upgrade. I have down graded to version 2.5.5.100 and for the last 9 hours have not dropped. This is the longest period of no internet drops in 5 days. I will keep updating but so far it is appearing that the last two firmware drops are causing the internet disconnect issues.
- dlplunkettMar 22, 2021Aspirant
The simple fix was roll back to V2.5.5.100 of the firmware as stated in the earlier comment and turn OFF the auto-update feature
V2.6.x.x has been garbage for a while... Netgear should pin to the top of the msg board to keep your ORBI pro at v2.5.5.100 until the issue is resolved fully
