yerge02
Mar 17, 2021Tutor
Orbi Pro SRR60 keeps disconnecting
Currently running the SRK60 Orbi Pro. My SRR60 router is running firmware version v2.6.2.200. Recently, my router has been losing its internet connection. This happens several times in a day. Eac...
odbammb
Mar 19, 2021Star
Let me recap my problem. It is specifically that the router keeps disconnecting from the internet. There is not a problem with connected devices dropping. The cable modem has been checked both when the router is working and drops the internet. The cable modem, lines and service are all good.
I have been wrestling with this for 5 days now since the latest firmware upgrade. I have down graded to version 2.5.5.100 and for the last 9 hours have not dropped. This is the longest period of no internet drops in 5 days. I will keep updating but so far it is appearing that the last two firmware drops are causing the internet disconnect issues.
Cheezdoodlez
Mar 19, 2021Star
odbammb wrote:Let me recap my problem. It is specifically that the router keeps disconnecting from the internet. There is not a problem with connected devices dropping. The cable modem has been checked both when the router is working and drops the internet. The cable modem, lines and service are all good.
Exactly my same issue. Glad the 2.5.5.100 worked for you too.
- odbammbMar 19, 2021StarStill no drops with firmware 2.5.5.100 . So both the last two firmware updates have been bad. With work from home this has caused me so much stress.
