yerge02
Mar 17, 2021Tutor
Orbi Pro SRR60 keeps disconnecting
Currently running the SRK60 Orbi Pro. My SRR60 router is running firmware version v2.6.2.200. Recently, my router has been losing its internet connection. This happens several times in a day. Eac...
blues2k
Mar 23, 2021Tutor
Updated the SRR60 today to 2.6.2.200 after noticing this morning that I was having issues staying connected. It started last night. Since I updated, it's worse. The SRR60 router just keeps disconnecting from the Internet. I have Spectrum, but I use a Netgear CM1000v2 modem. The modem is not losing it's connection. Rebooting it does not help. I notice when I'm in another room and suddenly my phone's wifi connection isn't working. Wired connections seem to work, but then I have to reboot the router and all connections go down. Insight won't connect when the wifi is down. And it's not alerting me to an outage. Logging in through a wired computer, I can get into the admin console which always shows Internet is not connected and wifi is down. Can anyone recommend a GOOD mesh system for a large old house??
LlamaLarry
Mar 23, 2021Luminary
The cheapest solution is to keep the one you've got and either roll back the firmware or carry out the DST/Traffic Monitoring changes mentioned in the thread.
- blues2kMar 23, 2021Tutor
Rolled back to 2.5.5.100 this morning and it's working just fine. Netgear needs more thorough testing!
- The-WheelyamMar 23, 2021Initiate
Thanks for the suggestion to downgrade the router to 2.5.5.100, it seems to be working but not dropping the internet overnight will be an achievement. Did you have to downgrade your satellites also? I can't seem to get the config firmware update area to show check boxes for the satellites. I've also not been able to cable directly into the satellite which I read was possible. I'll keep searching the community but thought I'd ask here.
- blues2kMar 25, 2021Tutor
I did not downgrade the satellites. They seem to be fine. This update seemed to only impact my router. SMH
