yerge02
Mar 16, 2021Tutor
Orbi Pro SRR60 keeps disconnecting
Currently running the SRK60 Orbi Pro. My SRR60 router is running firmware version v2.6.2.200. Recently, my router has been losing its internet connection. This happens several times in a day. Eac...
LlamaLarry
Mar 23, 2021Luminary
The cheapest solution is to keep the one you've got and either roll back the firmware or carry out the DST/Traffic Monitoring changes mentioned in the thread.
blues2k
Mar 23, 2021Tutor
Rolled back to 2.5.5.100 this morning and it's working just fine. Netgear needs more thorough testing!
- The-WheelyamMar 23, 2021Initiate
Thanks for the suggestion to downgrade the router to 2.5.5.100, it seems to be working but not dropping the internet overnight will be an achievement. Did you have to downgrade your satellites also? I can't seem to get the config firmware update area to show check boxes for the satellites. I've also not been able to cable directly into the satellite which I read was possible. I'll keep searching the community but thought I'd ask here.
- blues2kMar 25, 2021Tutor
I did not downgrade the satellites. They seem to be fine. This update seemed to only impact my router. SMH
