yerge02
Mar 16, 2021Tutor
Orbi Pro SRR60 keeps disconnecting
Currently running the SRK60 Orbi Pro. My SRR60 router is running firmware version v2.6.2.200. Recently, my router has been losing its internet connection. This happens several times in a day. Eac...
m8dhouse
Sep 17, 2021Initiate
Ok - bad news
It's not solved (for me at least). I installed the beta version.
Still same issue, kept rebooting at least 2x a day.
I get a lot of ACK DOS messages - nothing I can change there.
Logging - everything was turned off, no metering, ....
2 days ago it was really bad, constant reboots (like every 10 min).
After each reboot I checked the UI and what was interesting is that it said something like 'cannot connect to NTP' and the time was like way off. I even changed to cloudflare NTP but still same thing.
I gave up. I've now got a MikroTik router behind my modem and all 3 Orbi are now just AP. Everything works fine now (24h in - fingers crossed).
Please look into this because it's just not what I expect when shelling out this kind of money.
And make sure that logs are kept in memory after each reboot so you can actually do some serious debugging.
JosdV
Sep 17, 2021Star
I am not sure but this post doesn't mention anything about automatic reboots.
This post is about constantly loosing its internet connection.
Are we talking about the same issue?
