Murrayfield
Jan 22, 2025Tutor
ORBI Pro SRR60 Router and satellite
Hi
Recently purchased a Orbi Pro SRR60 and Satellite to install. I planned to have a admin network and a guest network on 2 different subnets. Admin network is in the 192.168.1.0/24 space and I planned to drop the guest network into the 192.168.3.0/24 space I could configure the Admin network okay in the main setup but I am flummoxed as to where I can configure my guest network IP settings. Everything I have read has said this is possible but nothing pops up and says now configure your guest network ip range. I am running V2.7.3.100 firmware
Any guidance appreciated
Thanks
Ian
1 Reply
Does the user manual give any information on Guest Network configurations?
Not sure if there is more in depth configuration for Guest Network. Mostly it's just setup and go and it's pre-defined by NG and uses 192.168.2.x subnet, at least on home class systems.
