LeeThai
Apr 11, 2022Follower
Orbi Pro SXK80 and SKS80 Region change
1. Login to Orbi/debug.htm page and enable telnet (tick telnet box)
2. telnet into Orbi and type these:
- root@RBR50:~# rm /tmp/firmware_region
- root@RBR50:~# echo WW > /tmp/firmware_region
3. Check the result, it should return WW
- root@RBR50:~# cat /tmp/firmware_region
Just saying, the above also works for SXK80 bought from America
Gives options
Australia
Europe
India
Japan
Korea
No RepliesBe the first to reply
