BIG9MM's avatar
BIG9MM
Apprentice
May 13, 2021
Orbi Pro SXK80 missing Daisy Chain?
I do not see Daisy Chain in the settings on the Orbi Pro SXK80,   Is it removed or does it still work?    Thanks!
  • schumaku's avatar
    schumaku
    May 15, 2021
    BIG9MM wrote:
    Very interesting. I’m actually running both of the Orbi Pro, Older unit, and a new unit. Older unit still has it, and newer unit I do not see it.
    it's not about old or new - the classic Orbi Pro has the daisy chain control (just like the legacy consumer Orbi systems), while Orbi Pro WiFi 6 does apparently not require a manual control.
    We were told several times the new Orbi Pro WiFi 6 system "does it right automatically". I'm not convinced this is true for all possible combination of wired and wireless backhauls however...
ProSupport for Business
