BIG9MM
May 13, 2021Apprentice
Orbi Pro SXK80 missing Daisy Chain?
I do not see Daisy Chain in the settings on the Orbi Pro SXK80, Is it removed or does it still work? Thanks!
- May 15, 2021
BIG9MM wrote:Very interesting. I’m actually running both of the Orbi Pro, Older unit, and a new unit. Older unit still has it, and newer unit I do not see it.it's not about old or new - the classic Orbi Pro has the daisy chain control (just like the legacy consumer Orbi systems), while Orbi Pro WiFi 6 does apparently not require a manual control.
We were told several times the new Orbi Pro WiFi 6 system "does it right automatically". I'm not convinced this is true for all possible combination of wired and wireless backhauls however...
BIG9MM
May 14, 2021Apprentice
Very interesting. I’m actually running both of the Orbi Pro, Older unit, and a new unit. Older unit still has it, and newer unit I do not see it. I hope one of the tech-support see this post and try to put somehow a way that we can see how all the satellites are daisychained similar to the home version . T
Thanks for your response!
JohnD333 wrote:
I have the same issue. 3 satellites plus base. All satellites connect to base. Despite a sat placed half way in between providing a much stronger/closer signal via windows, most distant sat goes all the way to base through 3 concrete walls. Results in “fair” signal and All devices attached have crap for speed. Still waiting for firmware to address this.
JohnD333
May 21, 2021Apprentice
Like Big9mm, I too hope one of the tech-support see this post and try to provide a way that we can see how all the satellites are daisychained and modify if/when we get better daisy chain results. Everything connecting back to the base is not how wifiPro6 was advertised. It clearly is not doing it "right."
also still waiting for solution for non-moving devices (fixed tablets for customer order entries, cameras, WiFi pc's, speakers, thermostats, etc) that still connect to a very "poor" base signal (35 feet away through concrete) after any firmware update, reconfiguration or reboot - and stay with that "poor" connection versus the "good" strong signal from the sat 10 feet away that they had before reboot etc . Power cycling all of those non-moving devices is a real pain, making remote firmware updates and reboots practically useless. No I cannot move the base router or hardwire the sats as access points. if I could do that I would not buy a "Pro" mesh system.
