WonKim's avatar
WonKim
ORBI PRO SXK80B4 Flow Internet
Hi, can everyone tell me, please one question that worry me. My newly bought Orbi Pro SXK80B4 with 4 satellits can not connect fast to the Intel AC Wireless AX210 card. The router is in the same ro...
  • plemans's avatar
    Jun 07, 2021
    a couple things.
    1. the is the community support forum. where members of the public help out. If you're having insight issues, I'd contact actual netgear support.
    2. the SXK80 supports 2400mbps over a 4x4 antenna setup with 80hz wide channels on the fronthaul 5ghz. It doesn't support 160hz wide channels.
    3. The intel AX210 is a 2x2 antenna setup that'll connect at 2400mbps IF you're using 160hz wide channels. The best it'll achieve on a 80hz wide channel is 1200mbps. You'd need a 4x4 wireless card to hit 2400mbps. So you're not going to hit 2400mbps on that router/card setup.
ProSupport for Business
