mrnome201's avatar
mrnome201
Orbi dropping internet
Hello - I have a RBR50 Orbi router and 1 satellite.  I am based in New Jersey.  I used to have Verizon TV and internet where the signal was coaxial.  I setup Orbi in AP mode to work w/ Verizon router.  I never had any problems with the setup.
I then decided to cancel Verizon TV service recently and keep the internet and I also upgraded internet speed from 50 to 200mbps.  So obviously now the signal is no longer coaxial, it's via ethernet.  I didn't want to pay for a new Verizon router so I am using Orbi as my router.  I am getting random instances on a daily bases where the Orbi drops the internet connection.  The easiest temporary fix is unplugging the ONT and plugging it back in.  If I go the reboot Orbi route, then the internet connection drop occurs more frequently.
I have read on forums that changing the SSID to be different for 2.4ghz and 5.0ghz signals has resolved the issue for some.  But the problem for me is that when I go and change the SSID for 5.0ghz for example from orbi61 to orbi61 5ghz, it reverts back to orbi61 if the connection drops again which it does.  Can anybody assist because I am at a loss.
  • Glad you got it working. Please mark your thread as solved so others will know.
    Enjoy.
    mrnome201 wrote:
    Hi - I reset my Orbi setup and it fixed the issue.  thank you very much.
  • FURRYe38's avatar
    I
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • mrnome201's avatar
      mrnome201
      • Mstrbig's avatar
        Mstrbig
        Master
        That was going to be my suggestion. When changing a router or remoming it and goint direct to the ONT, it is important to reboot or reset the Orbi router, if reset does not fix the problem. It's the same thing on a new install if dealing with a used Orbi router. Resetting it and rebooting the ISP modem/router eliminates those types of problems you experienced.
        Glad you got it working. I know how frustrating it can be.
