Dcranford
Apr 18, 2022Guide
Orbi Pro SXR80 not connecting to Centurylink Fiber.
I’m trying to connect to centurylink fiber. I’m directly connecting from the ONT to the WAN port on the Orbi. I have a static IP, I have tagged the WAN port with 201 and do not have pppoe credentials ...
BruceGuo
Apr 18, 2022NETGEAR Expert
Hi
can you try access Orbi Pri via https://orbilogin.com?
From your problem description, you cannot access might be due to LAN/WAN subnet conflict. If conflict, LAN IP of the Orbi Pro would be 10.0.0.1 (make sure your wired client uses DHCP mode and is able to obtain an IP.
Bruce
