jnz
Feb 14, 2021Aspirant
Orbi Pro Wifi 5 Business (SRR60) Questions - 3or4 SSID and Vlan/True segregation
Hi all - looking at the Orbi Pro Wifi 5 (no need for 6 as my devices don't support it) and I just had two questions I am having a hard time finding straigth answers for. 1) It appears at sometime...
schumaku
Feb 14, 2021Guru - Experienced User
1) Yes, four SSIDs.
2) No, the classic Orbit Pro (WiFi 5) does not support VLANs. The segregation is done by MAC filtering on the devices (router and satellites). There is no way for eg. expanding an existing multi VLAN network, it's a closed system.
jnz
Feb 16, 2021Aspirant
Thank you so much. So when the manual says the networks can not see each other [1], it is less true of a statement for the 5 than for the WIFI 6 version. For instance, someone on the IOT or Guest network could in theory hack into or intercept traffic on the employee network? I am just trying to determine if this is a legitimate threat to a small business where a few computers will be on the employee network doing banking / financial transactions. Trying to decide if it justifies spending the extra money for the WIFI 6 just for added security. At the end of the day I want a tech guy with no special network expertise to be able to configure and manage this in the most secure way!
[1] "When IoT devices connect to the IoT WiFi network, they cannot see other devices that are connected to the network and cannot access the local area network (LAN). Note: The router web interface calls the IoT WiFi network the Wireless 3 network"
