intofx
Sep 15, 2020Guide
Orbi pro wifi 6 (SXK80) can't do separate vlans in ap mode?
First of all Netgear phone support is horrible. 3hrs on hold and hung up on 3 times while trying to be transfered to a "expert who has been trained on this new product" is absolutely unacceptable. ...
- Sep 15, 2020
Hi,
In AP mode
1. you need to make sure your router has currect VLAN setting for LAN.
2. Make sure the uplinking port in AP is in trunk mode and use default profile.
3. Assign VLAN profile with VID that created in gateway to each wireless SSID
BruceGuo
Sep 15, 2020NETGEAR Expert
VLAN is supported in AP and Router mode. Do you have setup problems?
intofx
Sep 15, 2020Guide
Thank you for the quick reply. I figured the people overseas i talked with aren’t ready for this product.
Yes, the issue im having is when i turn on the vlan profile for each ssid and i connect i get a 169.x.x ip. Turning off the vlan profile for a given wireless connection and connecting works correctly.
Fw version 3.0.1.114
- BruceGuoSep 15, 2020NETGEAR Expert
Hi,
In AP mode
