secdoc
Jul 10, 2023Aspirant
Orbi pro wifi 6 (SXK80) can't do separate vlans in ap mode
I have installed the Orbi Pro Wifi 6 systems and have them in AP mode. I tried following or using the below solution as the mechanism to take/use the existing VLANs on my network. https://communi...
BasuKhodanapur
Jul 10, 2023Apprentice
Hi secdoc ,
Could you please share your netwrok topology ,
Since Orbi pro in AP mode . We need upper router which is running dhcp servers for defined Vlan's at orbi (which is in AP mode).
Other way put Orbi pro in Router mode , define vlan's Orbi has options to run dhcp servers in Router mode.
Thanks,
Basavaraj
- BasuKhodanapurJul 10, 2023Apprentice
Adding to above vlan isolation enable/disable can be done at upper router -where dhcp servers are running.
- secdocJul 10, 2023Aspirant
ere
Here is a basic layout of the network. I can get DHCP allocated IPs only when I specify the port on the switch is untagged VLAN assignments. If I treat the interface as a typical trunk port, the APs do not pass the VLANs or the DHCP communication even when I apply the VLAN Profile.
- schumakuJul 10, 2023Guru - Experienced User
For dhcp (aka bootp) the systems requesting dhcp have to do this on a native, untagged network. A switch (or for the sake an Orbi satellite or router) properly configured as an access port (with the pvid configured to associate the expected VLAN) will be able to forward the dhcp request. Direct on a trunk port, you can't connect any system and expect it to do bootp/dhcp request. Needless to say, eg. your security appliance must be configured to handle dhcp, too.
schumaku wrote:
secdoc wrote:If I treat the interface as a typical trunk port, the APs do not pass the VLANs or the DHCP communication even when I apply the VLAN Profile.
I understand that the native VLAN needs to be used. My point is that regardless of the native VLAN or trying trunking the traffic, the only way I am able to get DHCP assignments is through specifying untagged VLAN and the other VLANs do not get through.
