secdoc
Jul 10, 2023Aspirant
Orbi pro wifi 6 (SXK80) can't do separate vlans in ap mode
I have installed the Orbi Pro Wifi 6 systems and have them in AP mode. I tried following or using the below solution as the mechanism to take/use the existing VLANs on my network. https://communi...
BasuKhodanapur
Jul 10, 2023Apprentice
Hi secdoc ,
Could you please share your netwrok topology ,
Since Orbi pro in AP mode . We need upper router which is running dhcp servers for defined Vlan's at orbi (which is in AP mode).
Other way put Orbi pro in Router mode , define vlan's Orbi has options to run dhcp servers in Router mode.
Thanks,
Basavaraj
secdoc
ere
Here is a basic layout of the network. I can get DHCP allocated IPs only when I specify the port on the switch is untagged VLAN assignments. If I treat the interface as a typical trunk port, the APs do not pass the VLANs or the DHCP communication even when I apply the VLAN Profile.
