secdoc
Jul 10, 2023Aspirant
Orbi pro wifi 6 (SXK80) can't do separate vlans in ap mode
I have installed the Orbi Pro Wifi 6 systems and have them in AP mode. I tried following or using the below solution as the mechanism to take/use the existing VLANs on my network. https://communi...
secdoc
ere
Here is a basic layout of the network. I can get DHCP allocated IPs only when I specify the port on the switch is untagged VLAN assignments. If I treat the interface as a typical trunk port, the APs do not pass the VLANs or the DHCP communication even when I apply the VLAN Profile.
schumaku
Jul 10, 2023Guru - Experienced User
For dhcp (aka bootp) the systems requesting dhcp have to do this on a native, untagged network. A switch (or for the sake an Orbi satellite or router) properly configured as an access port (with the pvid configured to associate the expected VLAN) will be able to forward the dhcp request. Direct on a trunk port, you can't connect any system and expect it to do bootp/dhcp request. Needless to say, eg. your security appliance must be configured to handle dhcp, too.
- secdocJul 10, 2023Aspirant
schumaku wrote:
secdoc wrote:If I treat the interface as a typical trunk port, the APs do not pass the VLANs or the DHCP communication even when I apply the VLAN Profile.
I understand that the native VLAN needs to be used. My point is that regardless of the native VLAN or trying trunking the traffic, the only way I am able to get DHCP assignments is through specifying untagged VLAN and the other VLANs do not get through.
- schumakuJul 10, 2023Guru - Experienced User
Conclude, all the standard DHCP tasks are never forwarded accordingly to the appropriate VLAN when I get you right. Should not be a difficult thing for a software acceptance test 8-/
- DHCPDISCOVER: broadcast request to all DHCP in the network
- DHCPOFFER: answer to the DHCPDISCOVER
- DHCPREQUEST: from the client to the DHCP server, requesting IP or lease extension
- DHCPACK: acknowledged DHCP requests or DHCPINFORM requests
- DHCPNAK: refused DHCPREQUEST by the DHCP server
- DHCPDECLINE: ...
- DHCPRELEASE: ...
- DHCPINFORM: ...
- BasuKhodanapurJul 11, 2023Apprentice
Hi secdoc ,
Please refere below community link it may help you to configure vlans and port configurations.
Thanks,
Basavaraj
