ChukGleason
Sep 16, 2021Aspirant
ORBI Router, Webpage access - display is too large on iPad
Have my ORBI network working now, but when I use the web-page portal to access it using an iPad, the margins of the web-page are much larger than the display area of the iPad screen. I can move the d...
schumaku
Sep 23, 2021Guru - Experienced User
ChukGleason wrote:
BTW, I put in a request about 'Router Not Supported' in the ORBI app on this iPad, this seems to be a conflict with the R6300 router behind the ORBI.
Unrelated to the other router in front of the Orbi Pro system. The workaround might be that your Orbi Pro system is configured into router (NAT) mode. In general, the Orbi Pro and Orbi Pro WiFi 6 AX are intentionally not supported by the Orbi App intended for the "consumer" Orbi systems only. The Orbi Pro systems are supposed to be manged by the Netgear Insight App - however the functionality and monitor capabilities lack of many opinions known from the Orbi App.
