DigitalMaestro
Dec 27, 2021Star
Orbi SRK60 reverts to old password after reboot
When I change the password on my Orbi SRK60 it reports that the password change is successful. If I then logout and then back in I am able to authenticate with the new password successfully. However if I reboot the Orbi then try to login the new password no longer works. If I try the previous password then that one works. So it appears that the Orbi reverts to the old password after a reboot.
Has anyone else seen this issue?
Thanks
- JohnC_VNETGEAR Employee Retired
Hi DigitalMaestro,
May I know what is the firmware version of your Orbi SRK60? Is it running on the latest firmware? If not, please try to update the firmware first to its latest version and see it from there.
John
NETGEAR Community Team
Hi John,
It is on the latest firmware, 2.7.0.122. I also saw this behaviour on the previous firmware as well.
Thanks
