phoenix10386
Feb 07, 2022Tutor
Orbi SXK80 With Fiber Modem (ZTE F670L)
Hello! The existence of this vibrant community emboldened me to purchase an Orbi Pro SXK80 with confidence. I have had nothing but the best experience with it. Such a world of difference from my ...
DaneA
Mar 27, 2022NETGEAR Employee Retired
Just to clarify, is the ZTE F670L GPON modem-router set to bridge mode in order to function as a modem-only device? If yes, Kindly try these steps below:
1. Get a PC/laptop then connect it hardwired to the ZTE F670L GPON modem-router. Make sure that you are able to access the internet.
2. Disconnect the PC/laptop. Then, connect the ZTE F670L GPON modem-router to the WAN port of the SXR80.
3. Connect the same PC/laptop to the LAN port of the SXR80 and access the web-GUI of the SXR80.
4. On the BASIC Home page, select Internet.
5. Leave the 'Does your Internet connection require a login' No radio button selected.
6. Select 'Get Dynamically from ISP.'
7. On the 'Domain Name Server (DNS) Address' radio button, select Get Automatically from ISP.
8. On the Router MAC Address radio button, select 'Use this computer's MAC Address.'
9. Click Apply.
Note: If the Public WAN IP Address is still not registered to the SXR80, turn off the both ZTE F670L GPON and SXR80. After 5 seconds, turn on first the ZTE F670L GPON and wait for it to initialize. After the ZTE F670L GPON has initialize, turn on the ZTE F670L GPON. Check if the internet connection will be up.
DaneA
NETGEAR Community Team
