Partha21g
Jan 27, 2021Tutor
Orbi Wifi 6 PRO SXR80 Printing across SSID
Dear Netgear community, I need some help with my latest set up where i am trying to print across two SSID. Router and Satellite: Orbi Wifi 6 PRO (SR80) with two satellites running latest firmwa...
- Feb 21, 2021
Partha21g wrote:If i remove any attached VLANS then across SSID printing including airprint works. May be few more tweaks and i can get it resolved. The problem was largely due to the vlan settings.
Well, this will get you a single network, a single IP subnet and broadcast domain - this is why printing (Airprint - Bonjour based, [and also UPnP SSDP based printing as common on Windows]) works.
Partha21g
Jan 27, 2021Tutor
thanks. attaching debug log https://drive.google.com/file/d/1P7eF584DsCfPaygkfErgs6dIFe7L2-aQ/view?usp=sharing
printer is not pingable.
RaghuHR wrote:Hi Partha21g
Please send the debug files. You can log in to SXR80 by accessing https://<ip address of SXR80/SXS80>/debug.htm
Click on start capture and wait for few mins before you save the debug logs. Collect the debug logs from satellite as well.
Upload into google drive and send me link via PM.
Hope printer is pingable.
RaghuHR
Jan 27, 2021NETGEAR Expert
We have only router logs. Could you please share the satellite log as well if the printer is connected? BTW - mention the MAC address of your printer.
Thanks,
Raghu
- Partha21gJan 27, 2021Tutor
attaching satellite logs https://drive.google.com/file/d/1JcZj6Ru7O7cBhbY4iXyBBPiG2KsxSFI9/view?usp=sharing
Printer mac 6C:C2:17:1F:50:EB
intrestingly as i started the satellite debug, was able to print. Now stumped and curious to see what happened here.
- RaghuHRFeb 03, 2021NETGEAR Expert
Hi Partha21g
Are you still facing the issue? Please update your current observation on this.
Thanks,
Raghu
- Partha21gFeb 03, 2021Tutor
Yes still facing the issue.
I am uploading the Router and Satellite logs.
Router
https://drive.google.com/file/d/1bLQvSENHB0jrbJmcB--ZexhcvnmfAA7s/view?usp=sharing
satellite
https://drive.google.com/file/d/1i9aa2S1J3r-AgItyBdD_sCPvmhCI--2p/view?usp=sharing
