Partha21g
Jan 27, 2021Tutor
Orbi Wifi 6 PRO SXR80 Printing across SSID
Dear Netgear community, I need some help with my latest set up where i am trying to print across two SSID. Router and Satellite: Orbi Wifi 6 PRO (SR80) with two satellites running latest firmwa...
- Feb 21, 2021
Partha21g wrote:If i remove any attached VLANS then across SSID printing including airprint works. May be few more tweaks and i can get it resolved. The problem was largely due to the vlan settings.
Well, this will get you a single network, a single IP subnet and broadcast domain - this is why printing (Airprint - Bonjour based, [and also UPnP SSDP based printing as common on Windows]) works.
Partha21g
Feb 21, 2021Tutor
Some good news after some tweaks. If i remove any attached VLANS then across SSID printing including airprint works. May be few more tweaks and i can get it resolved. The problem was largely due to the vlan settings. Thanks to everyone who supported.
schumaku
Feb 21, 2021Guru - Experienced User
