TheGrumpyGent
Jul 07, 2022Tutor
Partial Use of Insight?
Hello! I have an SXR80 and I'm using some settings that are not currently available within Insight (for example, setting the wifi security to "WPA2-Personal [AES] + WPA3-Personal"). I'd like to use ...
schumaku
Jul 08, 2022Guru - Experienced User
Insight does have this capability to configure "WPA2-Personal [AES] + WPA3-Personal" aka. mix-mode e.g. with the WAC5xx and WAX6xx. looks like the recently added mix-mode to the Orbi Pro does not reflect this. Might be a simple oversight in the internal device/feature profiles. RaghuHR please investigate.
- TheGrumpyGentJul 13, 2022Tutor
Thank you both! Also, please let DaneA know; He's been gracious enough to help look into this for me.
- BruceGuoJul 13, 2022NETGEAR Expert
The WPA2/WPA3 mixed mode is only supported in Standalone now. We are working on supporting this feature in insight.
