jcharnet's avatar
Jan 19, 2021
Port Forwarding - SXR80
***Note -- This is not my router model #. I was not able to find my Orbi Pro - SXR80 in the drop down list.
I have just configured my new SXR80 router, alongside with AT&T Arris bgw210-700.
AT&T router is configured for IP PASSTHROUGH, and everything is working fine.
I'm trying not to configure port forwarding, that I had working in my AT&T router. I configured port forwarding in Orbi in Avanced Setup - Port Forwarding / Port Triggering.
Traffic is not getting to my internal ip/service. Did I miss anything in the configuration?
Anywhere I can look at logs to see where it's stoping?
Thanks a lot,
Joao.
  • I figured it out, I was using the wrong MAC address in my AT&T router for the IP PASSTHROUGH.
    I was using the Router Mac ADDRESS but I changed to use the Internet port MAC Address, and now it's all working.
    Thank you,
    Joao.
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi jcharnet
    Could you please enable remote access? (Go to advanced -> Adavnced setp->remote management). You can send me the port number via PM to me.
    Thanks,
    Raghu
    • jcharnet's avatar
      jcharnet
      Guide
      Thank you,
      Joao.
ProSupport for Business
